IROCs and 265/75R16's
Old Nov 24, 2014 | 09:16 AM
Jasongr81's Avatar
Jasongr81 is on a distinguished road
Default IROCs and 265/75R16's
Just put these on yesterday did some cutting and they fit gr8 no lift no tbar. Getting new shocks and tbars cranked this weekend.
Bad photo Ill get a better one in the daylight.
Attached Thumbnails IROCs and 265/75R16's-img_20901.jpg   IROCs and 265/75R16's-img_20881.jpg   IROCs and 265/75R16's-img_20871.jpg
Old Nov 24, 2014 | 09:28 AM
El_Beautor's Avatar
How much space do you have at the rear of the front fender? The picture doesn't show it very well but it looks like it will be tight when turning. Make sure you check how much clearance you have in that spot with the wheel turned. You may end up needing to trim a bit just to make sure you don't touch when you hit a bump and are turning.
All that being said, the wheel/tire setup looks really good. I hope you can run them without any trouble.
Old Nov 25, 2014 | 12:37 PM
Jasongr81's Avatar
I did have to cut some and on full turn it has about a 1/2" gap between the fender well and the tire. This weekend I am putting new shocks on and getting it aligned and the TBARS cranked some. I cut the front valance and the back of the fender and fender well.
For now there is no rub at full turn when driving. Yes it is very rusty I bought it from a guy in Northern Ohio.
Attached Thumbnails IROCs and 265/75R16's-b7a67f72-1076-4830-bbdb-c38ab3702c51.jpg   IROCs and 265/75R16's-5ad6b1fd-b614-4fc5-a1fa-06cad136f0c6.jpg
Old Nov 25, 2014 | 12:38 PM
Jasongr81's Avatar
The black pieces behind the wheels are the rubber from the inside of the fender well. Ill get a photo of them at full turn later.
420Blazin4X4
Tires and Wheels
Nov 24, 2014 08:57 AM
Shtbox
Tires and Wheels
Dec 8, 2013 12:06 PM
96BLAZE
Tires and Wheels
Apr 1, 2011 02:51 PM
97chevyblaze
Oct 2, 2010 10:45 AM
two1nine
Tires and Wheels
14
Nov 9, 2009 12:19 AM
