Just want to double check tire size.
Old Sep 12, 2011 | 06:43 PM
N3ROST4R's Avatar
N3ROST4R is on a distinguished road
Default Just want to double check tire size.
I am in desperate need of new tires. So I figure I'm just going to get the rims and tires I want and a body lift all at once. I have a 95 s10 blazer 4x4 that is completely stock right now.
I was planning on purchasing
performance accessories 2'' body lift
31x10.50R15, All-Terrain T/A KO Tire by BFGoodrich
and Pro Comp 15x7, 5 on 4.75 Bolt Pattern with 3.75" backspacing.
From everything I read I think this will work but I just want to be sure cause thats alot of money to drop. Thanks for your help guys. I just want to make sure this will fit and work together.
Old Sep 12, 2011 | 08:38 PM
AJBert's Avatar
Look for some rims with closer to 6" back spacing, like your stock rims. Otherwise, have fun!
Old Sep 12, 2011 | 09:10 PM
N3ROST4R's Avatar
okay what about 4.5" backspacing with those tires? Id like the tire to stick out alittle.
Or would I be better off doing a 30" with the 15x7 rim with 4.5" Backspacing?
Old Sep 13, 2011 | 10:41 PM
N3ROST4R's Avatar
Okay I think I've decided...please just a yes or no would be great to double check...I've just been reading so much about what fits and what doesn't I think I've confused myself more then when I started.
So what about 15x8 pro comps. 4.5 backspacing (or would 15x7's be better?), 30x9.5 bfg all terrain t/a ko's and 2" body lift?
I know you guys are sick of answering this but I can't find any for sure answers.
thanks so much
Old Sep 14, 2011 | 12:19 AM
AJBert's Avatar
I would go with the 15X7's and everything should work out just fine. Though, the 15X8's would work, too.
Just my personal preference on rim width with that tire size.
Old Sep 14, 2011 | 09:43 AM
N3ROST4R's Avatar
thanks for your help
kerander
Mar 6, 2014 09:21 AM
ntjoe
Aug 11, 2011 10:36 AM
wardlarson
Sep 2, 2010 10:39 PM
sporty_drew
Lifting Tech
Oct 12, 2009 09:38 AM
