largest tires for a 99 blazer with no lift?
Old May 24, 2013 | 07:27 AM
drealot's Avatar
drealot is an unknown quantity at this point
Default largest tires for a 99 blazer with no lift?
I have a 99 chevy blazer 4dr 4x4 base model, I want to upgrade the wheels & tires.
I want to up grade to 15x8? & the widest, basically biggest offroad tire I can, what sizes of tires would work without body modification (trimming,lift)
Old May 24, 2013 | 12:05 PM
Diaita's Avatar
It depends on the wheel offset. The further the tire sticks out, the smaller the tire you can fit. Stock wheels can fit a 31" tires with some rubbing against the frame and rear of the front fender. A 15x8 wheel with a RWD offset will reduce your tire size to nearly stock.
Old May 28, 2013 | 05:56 PM
tibby's Avatar
Default .
Like said above, you never listed the backspacing of the wheel. But with no modification to the body and no lift, the biggest tire you can run SAFELY is a 30/9.5/--. (the -- indicates whatever size rim you are running) Anyone who says different is crazy. Any rubbing on the frame or body is asking for trouble. You could destroy your tire or worse, flip your blazer if the tire comes in contact with the frame.
Old Jun 5, 2013 | 10:23 PM
truc.karl's Avatar
truc.karl is on a distinguished road
I agree. Your rig can accommodate 30x9.5x15 tires with no modifications. If I were you I would put some lift so I can have a more aggressive set of tires for off roading.
Old Jun 13, 2013 | 11:53 AM
gibsonZr2's Avatar
gibsonZr2 is on a distinguished road
31x10.50 will rub with no lift so yeah 30s
MWP
Lifting Tech
Jan 18, 2014 07:07 PM
imnotmikal
Tires and Wheels
May 29, 2010 09:24 PM
udeluz
May 26, 2009 08:45 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
blazerbob
Tires and Wheels
Mar 19, 2007 08:38 PM
