Lug nuts for cragar soft 8s
Old 11-23-2010, 11:12 AM
99 blazer's Avatar
99 blazer is on a distinguished road
Default Lug nuts for cragar soft 8s
What size lug nuts do I need for soft 8s Im looking at summint racing..Its 630 for mastercraft courser ct's and cragar soft 8s 15x7 with 4.75 bolt pattern and 4in. backspacing is that right?
Old 11-23-2010, 11:13 AM
Benedict1337's Avatar
you can use the same lug nuts that are on your stock rims. You aren't changing the hubs just the wheels. You can buy lugs that look nicer and harder for people to steel...
Old 11-23-2010, 12:32 PM
mdehoogh's Avatar
Yep, the lug nuts you have now will work fine.
If you want to buy new ones though, the threadsize is M12x1.5.
Old 11-25-2010, 01:53 AM
99 blazer's Avatar
Old 11-25-2010, 12:29 PM
mdehoogh's Avatar
yeah they'll work. they will stick out a little wider (2inches) than the stock wheels. should look close to the pic in benedict1337's sig a few posts up
Old 11-26-2010, 01:00 PM
blazinloud's Avatar
i bought chrome or whatever lugs and effed em up with my tire iron
Old 11-26-2010, 11:31 PM
99 blazer's Avatar
could i put 30x9.5x15 tires on here with no issues? stock height 4x4 2 door..
Old 11-29-2010, 10:11 AM
blazinloud's Avatar
depends on brand. they will fit on, but may still rub when turning
Old 11-29-2010, 11:11 AM
they will most likely rub if you get those cragars.
Old 12-01-2010, 10:42 AM
99 blazer's Avatar
Ok I got the wheels but around the lip is all nicked up..did anyone else have this problem?
Quick Reply: Lug nuts for cragar soft 8s
