New Tires
Old Feb 17, 2013 | 02:58 AM
newguy's Avatar
Originally Posted by Twip
hahaha. i have been looking at tires for like 2 months because i need some badly, but i do so little driving in mine its not that pressing of an issue. i looked at the BFG's but i just cant afford a $170 a tire. for some reason i cant find them much cheaper than that...
when i was at pick and pull the other day i missed out on a set of almost brand new ones. probably about 85-90% tread left. i was kickin myself in the butt so hard for missin out on that...
https://www.treadwright.com/p-8-235-...ler-m-t-c.aspx
Old Feb 17, 2013 | 09:25 AM
Twip's Avatar
Originally Posted by newguy
Yes they are, For some reason the tires that are on the truck (also 235/70/15) measure just over 27 inches , these measure just over 29 uninflated!
thats because your new ones are 235/75/15. the side wall is approx. 5% taller. hence the 3 inches. basically a 235/75/15 is a shy hair from a 30" tire. and you figure the tires that are on your truck now have worn down a bit from use. i have 235/75/15 on both my 2wd and my 4x4 and right now the 4x4 doesnt rub, but the tires need replacing. on my 2wd they rub a little bit but its no biggie. just a little on the sway bar and thats it.
thanks for that web site BTW. i will have to check it out. i just dont know about running recaps...but then again, i really havent heard anything bad about them either... i will have to do more research.
Old Feb 17, 2013 | 09:42 AM
newguy's Avatar
From my research before I bought them, I couldnt find any bad reviews about treadwright. I feel that retread tech has probably come a long way, they are DOT cert. Are green and cheaper. The rubber you see on the highway are from truck recaps which is a completely different type of recap. These you can use front or back. Only on trucks and buses can they only be used the back. some more links
Retread Myths - Tire Retread & Repair Information Bureau
Old Feb 19, 2013 | 10:13 AM
newguy's Avatar
So the tires have been at the garage since sat. They mounted them and then their balancer broke. Should be done today I post pictures when I have them on the truck. Hopefully tonight
Old Feb 19, 2013 | 02:19 PM
newguy's Avatar
all set, a little noise on the road but not bad
I need to get some caps
Attached Thumbnails New Tires-100_0467.jpg   New Tires-100_0466.jpg   New Tires-100_0465.jpg
Old Feb 19, 2013 | 05:59 PM
Twip's Avatar
yep!! looks good man.
BTW, the other reason that they dont put recaps on the front of trucks is if they blow out and the cap comes off, it normally takes out the hood/fender since its made out of fiberglass and sometimes they will even take out the air cleaner on the side. im still looking into them though because its not like there will be a lot of weight on them plus i wont be speeding down the highway.
Old Feb 19, 2013 | 06:01 PM
newguy's Avatar
For everyday driving they`re fine, I like em
Old Aug 31, 2021 | 09:24 AM
Vahomboy's Avatar
Vahomboy is on a distinguished road
Looks good!
Striker911
Mar 6, 2014 11:56 AM
98Ltblazer
Aug 19, 2010 07:06 PM
yazan84
Dec 30, 2007 11:19 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
blazerbob
Tires and Wheels
Mar 19, 2007 08:38 PM
