Noob Question
Old Mar 22, 2008 | 09:19 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Noob Question
So, i would like to get a bigger tire. I went to a tire place today and they said they could put on a 18" rim with bfg all terain tires an not have it rub. Can that be done? Im goin for the rugged look with some black rims. I would like them to stick out a bit as well. Any help greatly appreciated.
Old Mar 23, 2008 | 01:06 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Noob Question
dont want them to stick out without any suspension mods/fender trimming. It is possible to make 18's with a BFG AT fit but they would look like low pro BFG AT's, which IMO defeats the purpose of having a tough tire. I have them because they are strong and have a very high puncture/cut resistance (I have no spare)... but thats just my opinion.. Lastcoupe has BFG AT's on 17's on his truck and they look awesome.. look at kis photo gallery..
Old Mar 23, 2008 | 02:48 PM
I think i might get like a 16" or 17" wide rim, like 6" backspacing. That should work shouldnt it?
Old Mar 23, 2008 | 06:14 PM
Um... 16" or 17" WIDE??? Or are you speaking 16" diameter or 17" diameter...
A 30" outside diameter tire is as large as you would want to go without other modifications (lift, trimming, etc).
So if you start with say a 235/80R15{metric size close to a 30x9.5R15} (~30" OD with 9.25" section width and 7.4" sidewall height), if you went with a 16" rim, you would drop to a 235/75R16 (~30" OD with 9.25" section width and 7" sidewall height). With a 17" rim, 235/70R17 (~30" OD with 9.25" section width and 6.5" sidewall)
Old Mar 23, 2008 | 06:54 PM
a_tack's Avatar
how sweet would a blazer look with 17" wide rims?? lmao..... I'm sure he meant 17" diameter.. simple mistake, I am not lmao @ the op... just at the mental image of tires sticking out 12-13 inches from the fender... I smell a photoshop opportunity..
Old Mar 23, 2008 | 09:45 PM
Lol yeah sorry bout that i ment diameter, The biggest body lift for a 2000 blazer is 2" right? cant find 3" anywhere. But im thinkin that maybe ill get some cragar soft 8s with a 31 or 32 tire will that work?
Old Mar 25, 2008 | 12:21 AM
a_tack's Avatar
31 yes, 32 no
ScottWV
Jan 25, 2010 07:15 AM
ABN31B
May 26, 2009 08:12 AM
SillyLittleBlazer
Nov 24, 2007 07:02 PM
jug
Headers, Intake, & Exhaust
Oct 20, 2007 01:16 AM
strongboy2005
Feb 3, 2006 08:14 PM
