Painting the stock rims
Old Aug 26, 2009 | 11:52 PM
wlorton's Avatar
Default Painting the stock rims
So its commonplace for people here to paint stuff black... I was thinking with my red blazer that I could paint my rims black and then the teardrops red to match the vehicle or doing the inverse of that... any input would be great... I am currently sizing this and a few other projects up to set up a budget and begin to purchase supplies....
thanks
Old Aug 29, 2009 | 01:04 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
I painted my swirls black. Its fairly simple, but you have to be methodical about it when you are using rattle cans.
-Clean the rims with rim/tire cleaner (Simple Green works wonders) then dry them.
-Sand the area to be painted with medium then fine grit. You don't have to go all the way down to the metal.
-Mask it off good, paint them carefully with primer. Let dry, then you can wet sand the primer.
-When spraying the color coat, first a light coat, then a fully covering allowing no more than a couple minutes between. Spray paint dries fast.
-I clear-coated mine with "high performance wheel coating" that you can buy at most autoparts stores, so you want a base coat that will accept a clear coat. (Fusion, regular krylon, or colormatch spray paint is not a good idea)
-Unmask before its fully dry, then let dry overnight in climate-controlled area just to be safe.
Old Sep 1, 2009 | 06:48 PM
CraigSnedeker's Avatar
I wanna do this also. I'll let you know when I find a way.
budah93
Feb 25, 2013 02:26 AM
slaughterbaby
Jan 2, 2012 03:10 AM
BlkonBlkBlaze
Tires and Wheels
20
Oct 8, 2009 08:13 PM
mysons95
The Chop Shop
Nov 5, 2008 06:37 PM
EuroGoldLS
Mar 24, 2008 11:59 PM
