People with wheel spacers
Old Feb 26, 2008 | 10:19 PM
  #21
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Default RE: People with wheel spacers
Wouldnt a lower offset wheel do the same thing as spacers except without that extra piece that can come loose or be over tightened?
Old Feb 27, 2008 | 02:18 AM
  #22
thegr81's Avatar
I would just run a hub centric wheel with the backspacing your looking for!! Spacers imo are a no no, some have had luck and some like me have had bad luck!!
Old Feb 27, 2008 | 08:15 AM
  #23
ORIGINAL: Idriveachevy
Yes, rims with a lower back spacing would do the same thing. With spacers, you have an extra set of lugs in the mix.
Spacers are common for people that are trying to change the bolt pattern to open up to a wider variety of rims.
Old Feb 27, 2008 | 06:29 PM
  #24
willjones's Avatar
Can you change our lug pattern to a 5x4.5 with just a wheel spacer.
Old Feb 27, 2008 | 06:47 PM
  #25
mdehoogh's Avatar
i know i have seen some that allow you to put a 5x5 wheel on a 5x4.75 hub but im not sure about 5x4.5
Old Feb 27, 2008 | 06:59 PM
  #26
willjones's Avatar
Well if they do it would make my life so much better, because I have 2 sets of rims from my Jeep that I would love to use.
Old Feb 27, 2008 | 07:21 PM
  #27
Blazin_Jason's Avatar
Nope no such luck Will. Or maybe?
Old Feb 27, 2008 | 07:24 PM
  #28
Jigg's Avatar
Jigg is an unknown quantity at this point
ORIGINAL: willjones
You sure can
Thing is... you're already adding a 1" spacer, and then you'll need to find a jeep rim with a LOT of backspacing to make up for that. Like, close to 6" of backspacing.
Old Feb 27, 2008 | 07:54 PM
  #29
willjones's Avatar
Well now I am going to have to think on that. My Jeep rims are only like 4inches of back spacing. I think that they are going to stick out way too much.
Old Feb 27, 2008 | 08:27 PM
  #30
Jigg's Avatar
Agree'd... they'll stick out 4" more on each side. 1" for the adapter, and 3" more for the rims. Waaaaaay too much, in my opinion.
