rally's
Old Oct 19, 2009 | 08:32 PM
stevo's Avatar
stevo is an unknown quantity at this point
Default rally's
are there any of these style of chevy rallys made in the s10 bolt pattern
ive seen them on a few s10 blazers, and think they look sharp
i love these wheels
Attached Thumbnails rally's-6132934995780-chevy-rally-wheels-300.jpg   rally's-wheel-t1.jpg   rally's-5734802553353-1989-s10-blazer-2wd.jpg
Old Oct 19, 2009 | 09:42 PM
DriftinBlzr's Avatar
DriftinBlzr is on a distinguished road
If they fit S10 Blazers they will fit an S10. All the S-series vehicles use the same 5x4.75 bolt pattern. With that said, look for rims from early F-bodies (Camaro and Firebirds), A-Bodies (Chevelles, El Caminos, GTO's, Grand Prix's, Monte Carlo's are a few examples), and 60's Corvettes. They all share the same 5x4.75 bolt pattern as the S10.
The only problem you may have is brake caliper interference as some of the rally rims came in 14" and others came in 15" (in drum brake and disk brake specs) and if you have a 4WD then the rims will most likely stick out from the fender as they all have 2WD backspacing.
Later, Doug
Old Oct 20, 2009 | 07:29 AM
Yep:
Mine are 15x7s.
Old Oct 20, 2009 | 01:58 PM
stevo's Avatar
well when i said s10, i meant the s10 models
but thanks, so basically i can get them off any 5 lug car of the 60's and 70's?
Old Oct 20, 2009 | 02:14 PM
You can get them from any platform that I mentioned. I think some of the B-bodies use a 5x5 bolt pattern and won't work.
Later, Doug
CraigSnedeker
Jan 26, 2010 01:18 PM
CraigSnedeker
Oct 27, 2009 08:18 AM
warthogdriver
Oct 21, 2009 06:41 PM
CraigSnedeker
Oct 6, 2009 07:35 PM
m00nwater
Apr 7, 2006 10:11 PM
