Rim Chabge
Old Oct 19, 2019 | 06:19 AM
donald_archer's Avatar
donald_archer is on a distinguished road
Default Rim Change
Hi sorry to bother if this has been dealt with before.
I had a set of new Hancock winter tires on GMC rims given to me by a friend who had a 2000 Jimmy 4WD. My question is will the rims fit my 1998 Chevy Blazer 2WD. The tire size is exactly the same I have concerns that the rims may not fit though.
Any help would be appreciated
Regards
Don
Old Oct 19, 2019 | 10:12 AM
Hey, so I think there will be an issue, I know when can put 2wd rims on our 4x4 because they stick out... but I think there will be rubbing on the inside because 4wd rims sit inwards... can add some spacer without a problem, or take them to a shop and get them put on your rims...
Old Oct 22, 2019 | 05:28 PM
Thanks DonL. You are right wont fit. Was worth a shot though Thanks for the input
Regards
Don
Old Oct 22, 2019 | 06:21 PM
No problem.
Old Dec 14, 2019 | 03:05 PM
bravo99's Avatar
I'm looking at a set of enkei 15 by 8, 4 inch backset. Does that compensate for the 15 by 7, 6 inch back set? Current rims are bravada stock alloys. I'm not worried about sticking out, I'm worried about caliper clearance and rubbing in...
Old Dec 15, 2019 | 10:44 AM
Hess13x's Avatar
They will stick out more. They will clear calipers and suspension. The problem you may run into is tires hitting the back of the front fenders when you turn.
Old Dec 15, 2019 | 12:52 PM
bravo99's Avatar
thank you Hess I will look out for that if I get them.
Old Dec 17, 2019 | 01:34 AM
So wait; The 2wd rims when installed on a 4wd Blazer stick out more than the 4wd rims? By how much? Is installing the 2wd rims a cheap/simple way to increase the stance width on a 4wd Blazer?
Old Dec 17, 2019 | 03:27 AM
I want to say it's about 2-4 inches difference. So yes they do change the stance... not sure if it's cheaper tho lol... depending on prices of the parts you get...
Old Dec 17, 2019 | 09:00 AM
Hess13x's Avatar
Yes 2wd wheels have 4 in back spacing I believe and 4wd have 6 inch back spacing. I have 2wd wheels on my 4x4
Nyshadow
Tires and Wheels
Jan 1, 2019 09:23 PM
Karcinagin
Tires and Wheels
Oct 11, 2011 08:01 PM
btmbass
Tires and Wheels
Mar 23, 2011 12:03 AM
Radar0066
Tires and Wheels
Jan 9, 2010 04:34 PM
TurboAddiction
Tires and Wheels
Oct 18, 2008 07:12 PM
