Rim specs
Old Jan 13, 2012 | 03:09 AM
nardster's Avatar
nardster is on a distinguished road
Post Rim specs
Tryin to put some 24s on my 96 4x4. I know it can be done stock theres gotta be a way. Need some tire sizes,offset,rim specs please
Old Jan 13, 2012 | 09:23 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
u may need a lil lift to stuff those. maybe 1" body...? im not sure.
Old Jan 13, 2012 | 01:26 PM
nardster's Avatar
u kno a good lift kit i can get? and mabe how much it will run me?
Old Jan 13, 2012 | 01:52 PM
duxtoyz's Avatar
if ur wanting a body lift go to ebay, cheap and good, theyre all polyurethane....and u can find suspension lifts too, which are shackles and keyways.
Old Jan 13, 2012 | 03:59 PM
El_Beautor's Avatar
To do it stock, without lifting you're going to need a rim with 6" of backspacing (factory on a 4x4) and your total rim+tire height can't be larger than 29" and width no more than 10" on a 7" or 8" rim. Anything bigger than that and you're going to have to lift. I ran 255/70 15's on factory rims at factory height without rubbing. That's a height of 29", and a tire width of 10". Much taller or wider than that would start rubbing on the back of the front fender when turning and compressing the suspension.
A t-bar and shackles lift will get you about 1.5-2" depending on how much you want to stress your front components. A body lift will get you 2" straight up. They're pretty easy to install on a 95-97 Blazer.
Old Jan 16, 2012 | 01:48 AM
nardster's Avatar
thanks for the info guys
evuldrporkchop
Mar 4, 2013 01:20 AM
pontiacsouth
Jun 30, 2006 03:40 AM
mars004
Feb 10, 2006 03:51 PM
c95blazer
Engine & Internal
Dec 16, 2005 07:17 AM
Grkblazer
Tires and Wheels
Sep 4, 2005 02:54 PM
