Rims for my blazer?
Old Jun 17, 2009 | 09:19 AM
Frenchyap30's Avatar
Frenchyap30 is on a distinguished road
Default Rims for my blazer?
Hey everyone, i have a 2003 2dr chevy blazer with the zr2 package and i am looking for a good set of rims that arent too expensive that i will be able to put a beefy tire on for off roading. the only lift on the truck is the stock 2in body lift and i dont think im guna lift it anymore so im basically looking for rims that i wont have to modify the truck for
Old Jun 17, 2009 | 11:05 AM
oktain's Avatar
The factory rims are 15"x7", it's up to you if you want wider/larger.
The bolt-pattern is 5x4.75"
I have a set of winter tires, and all I did was get a factory set from the wrecking yard... they weren't perfect condition though, I had to clean them up and do some sanding/painting along with a couple shots of clear.
Just a set of black steel rims would work too, you'd have to be more specific if you want chrome/nice rims or just any set of rims to throw some mudders on.
Sorry, but I forget what the stock backspacing is... 6" I think... SWARTLKK would know.
Old Jun 17, 2009 | 01:15 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the stock backspacing for 4wd is 6".
Frenchyap30- zr2's are 2" taller than regular blazers,but they do not have a body lift installed from factory. its a combination of a different suspension and frame that makes the zr2's taller.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
Cojack2
Tires and Wheels
14
Feb 18, 2011 05:42 PM
Millertime21
Feb 19, 2007 02:28 AM
batzer
Tires and Wheels
Oct 13, 2006 01:21 AM
Liltruck
Tires and Wheels
Oct 20, 2005 12:38 PM
