Spacer Help
Old Dec 19, 2018 | 03:26 PM
Originally Posted by Jakebax84
I would like my tires flush with my finders on my 98 LS 4dr 4x4. So I would need 1" spacers on the front and 3" spacers on the back? Seems like an awfully large spacer for the rear. Is that safe? Is there a certain brand that is superior? Is there a safer brand? Where can I purchase these? How would I go about torquing those down?
If you look at my post immediately above yours, you'll see the track widths for 1999 models:
Drive, track width (front/rear)
2wd 55.0"/54.6"
4wd 57.2"/55.1"
ZR2 61.1"/59.0"
With this in mind, if your goal is to get the track widths to be the same then the least aggressive way to accomplish that is to install on the rear only, 1" or 1.25" spacers. By only installing them on the rear, you are not changing any of the front end geometry which I, with nothing else than my gut to go by, felt likely a good thing to avoid doing. And ditto on using only high quality metal, studs and to the spacers being hub-centric in design.
I installed 1.25" spacers that I purchased off of eBay. One reason I chose the 1.25" ones is that I would know that the spacer would be thick enough so that the lug bolts would not stick out from the spacer.
Here are pics of the ones I installed:
The box
The spacer before install
Spacer installed
thatguy1728
Tires and Wheels
Feb 24, 2018 07:19 PM
James Tapley
Tires and Wheels
Nov 21, 2017 01:11 PM
philipfreire
Tires and Wheels
Feb 25, 2017 10:13 AM
dharvey4651
Tires and Wheels
Jun 5, 2013 01:39 PM
GioMach
Suspension Tech
Mar 24, 2013 10:41 AM
