Spare tire info...
Old Jan 19, 2009 | 05:40 PM
RockingRobin69's Avatar
RockingRobin69 is an unknown quantity at this point
Default Spare tire info...
My spare tire was recently stolen & I'm in the process of replacing it. After calling a few dealerships & salvage yards, it seems that I could have a real tire or a donut. None can give me a solid answer. I have a 2001 4 door, 4X4 LS. Can anyone offer any help in this? Thanks.
Robin...
Old Jan 19, 2009 | 06:21 PM
mdehoogh's Avatar
Default RE: Spare tire info...
Unless I've misread your post, I don't see a very clear question. Are you trying to find out what size tire you need for a spare?
To the best of my knowledge, if you have a 4-door truck or a 2-door with the rear tire carrier, you're spare should be a full sized wheel/tire. If you have a 2-door without the rear tire carrier (i.e, the spare is mounted inside the rear cargo area) then your spare will be a limited-use tire (donut).
Regardless of what sized tire you had before it was stolen, if I were in your position, I would replace it with an actual full-sized wheel/tire.
Old Jan 19, 2009 | 06:24 PM
1991whiteoutblazer's Avatar
1991whiteoutblazer is an unknown quantity at this point
I would also invest in a lock set that can be had from a dealer or sometimes on ebay.
Old Jan 19, 2009 | 07:16 PM
WolfPack's Avatar
Put it on your roof (keeps the short theives out), and lock it down (keeps everyone else out)
Old Jan 19, 2009 | 08:34 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
my truck is a 974dr 4x4and it has a donut thatwas mounted under the truck
Old Jan 19, 2009 | 08:52 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
My 2dr has a full size spare(235-75-15) mounted inside, takes up alot of room though. I plan on doing what WolfPack did when I get a roof rack like his.
Old Jan 19, 2009 | 09:02 PM
mdehoogh's Avatar
ORIGINAL: xmradioguy
ORIGINAL: volfan4
So I guess my information was incorrect. I always thought the interior mounted spares were donuts and the exterior were full-sized...
Old Jan 19, 2009 | 09:33 PM
WolfPack's Avatar
Remember that these spares could have been replaced at any time by a previous owner.
Matt I thought you were spot on. Inside = donut, outside = fullsize.
Old Jan 19, 2009 | 09:52 PM
volfan4's Avatar
RPO codes on my Blazer:
ZBG= TIRE SPARE , P235/70R15 - 102S WOL R/PE ST TL ALS
PNV= CARRIER, OUTSIDE SPARE TIRE MOUNT NOT DESIRED (RETAIN
It may have not been standard equipment, but it was ordered that way.
Old Jan 20, 2009 | 09:20 AM
Hanr3's Avatar
Both my '87 (2dr4x4) and '93(4dr4x4) had fullsize spares in the cab. My '00(4dr4x4) has a fullsize under the back. Maybe the difference is 2wheel drive verse 4wdr? As in 2wheel drives get the donut, although I would just get a steel rim from the salvage yard and put on a fullsize tire.
nails5240
Jun 11, 2006 04:24 PM
c4gibson
Apr 19, 2006 06:02 PM
RacerX_96
Apr 4, 2006 01:14 AM
Ricks Blaze
Jan 29, 2006 06:54 PM
buckwheat
May 20, 2005 04:04 PM
