Is there a difference in wheels...
Old May 20, 2009 | 09:38 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
Default Is there a difference in wheels...
From 2wd, and 4wd S-10 blazers? Would a wheel from a 2wd work on a 4wd?
Old May 20, 2009 | 09:39 AM
Sisk's Avatar
I'm assuming you mean rim...and if so, then rims are all based on bolt pattern. All Blazers have the same bolt pattern (as far as I know) so they can be interchangeable.
Old May 20, 2009 | 09:45 AM
nj4x4blaze's Avatar
The difference between a 2wd rim and a 4wd rim is the back space. 2wd rims are 4" back space while the 4wd rims are 6" back space. Yes you can put 2wd rims on a 4wd but the rim is going to stick out past the fenders roughly 2". Look up Georgesblazah, there are pictures of his truck with 2wd S10 ZQ8 wheels.
Old May 20, 2009 | 09:54 AM
Found a set of 2wd alloys from a S-10 pickup 98+. Now that I know the back spacing is difference I may just look for a set of stock 4wd wheels.
Old May 20, 2009 | 10:10 AM
Sisk's Avatar
Learn something new everyday lol...I didn't even think about back spacing.
Old May 23, 2009 | 01:44 AM
001blazer's Avatar
001blazer is an unknown quantity at this point
Default Corvette wheel on Xtreme
Any one knows if the 11" Corvette wheels can feet on my 01 blazer xtreme using spacers, I been told that I can use 10" with no problems (using spacers) But it I can fit the 11" will be perfect.
Old May 23, 2009 | 02:09 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
stinz
Feb 5, 2013 12:40 PM
fast eddy
Performance & Brainstorming
Aug 1, 2010 09:45 AM
mcaanda
May 23, 2009 04:04 PM
bitbandit
Tires and Wheels
Feb 12, 2008 02:41 PM
