tire size question - NOT A NOOB
so i have done my homework and a lot of researching but i need some input. I have a stock 2000 4wd 4dr with 235/75/15 kumhos on american racing rims. I want some beefier tires so I am thinking about picking up a set of general grabber at 2. The size i'm looking at is 265/70/15. By doing a simple math equation this is how big they are converting from metric:
height = ((265*70*2)/2550 + 15) = 29.54"
width = 265/25.5 = 10.39"
i have stock shocks, i have not cranked the t-bar, and not running shackles. do you think i will have any rubbing problems or should i step down to a 255/70/15? Thanks in advance!
i think i'll be alright with the back spacing on the wheels. i have seen a few other blazers with the same exact rims and backspacing running bigger tires. my main concern is the sag i get from the OEM shocks. they are old and i need to replace them. i would love to run the 265s if i can but i may just go with the 255s to be on the safe side. and yes the 255s look a lot better than the 235s. that is another reason i want to go bigger
i have a stock 96 and want to run 31in wranglers or the 265s and a t bar crank i know the 31s rub when steering is cut all the way but i dont know if the crank will make much difference and im also thinkin about gettin a 2in body lift what do you all think
you are def gonna need to get a 2in body lift or shackles, t bar crank, and trimming to get the 31's to fit. the 265/70 are only 29.54". big difference between the 31 and the 265/70.
going with the 255 will definately add more "bulk" to the look of your truck. and do a slight crank if it's a little close. it'll settle a little after you do that anyways, so it should all work out good.
hmmm.......what do i think?........
besides the extreme run-on post.......seriously, read the section. there's TONS of info regarding the exact same question you just asked (along with a s**t load of other guys).
***edit***
but either way, from experience, the most you can stuff on a stock suspension 2nd gen 4WD is a 245/65/R17 (29.53" O.D.)
***edit***
***UPDATE***
So my buddy gave me a set of brand new BF Goodrich Long Trail AT tires for free. He got them in a trade and didn't need them. The size on the tires are 31 x 10.5 x 15. If you read the previous information I am currently running 15 x7 American Racing Aero Wheels w/ 235/75/15 Kumho AT on a '00 Blazer 4wd. I have a bone stock suspension. Would a 2" body lift give me sufficient clearance for these tires. Would I still need to do a T Bar Crank? Any recommendation on body lift kits?
