Tires and 4x4
Old Jun 3, 2008 | 08:07 PM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default Tires and 4x4
Hey folks. I had an 89 Jimmy and with the older trucks i know you had to have 4 tires all about even treadwear or you could cause problems having the axles spinning at different speeds. I've heard the newer trucks are more forgiving? I just had to replace two tires and the tire shop said they think if i put them on the back, they will wear enough to even out with the fronts by winter...but now that they're on the truck i'm not so sure. The tread difference is huge. Should I get another pair in short order or is it not really a worry? I have a 99 zr2 and the tires are Cooper Discoverer A/T's on the front and the new ones are ATR's on the back.
thanks
Old Jun 3, 2008 | 08:16 PM
Default RE: Tires and 4x4
When not using 4wd, you have nothing to worry about. You just shouldn't run 4wd on high traction surfaces (ie pavement) until they are worn in.
Old Jun 4, 2008 | 07:23 AM
Smoked's Avatar
Okay thanks... i'll keep an eye on the new ones and before the fall if they're just not close enough then i'll get a pair to match. I have 5000km trip out east coming up in a month so i should have the miles to wear em in
Blazonaire
Tires and Wheels
Oct 14, 2015 11:32 AM
Striker911
Mar 6, 2014 11:56 AM
98Ltblazer
Aug 19, 2010 07:06 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
blazerbob
Tires and Wheels
Mar 19, 2007 08:38 PM
