What soft 8s will fit
4 inch backspacing isn't far away from 4.5 inch backspacing at all. The tire will stick out just a tad bit more. Or for an even closer fit to 4.5 inches of backspacing, the 2nd link has Crager's with 4.25 inches of backspacing on a 15x7 rim. That'll look good man!
Crager Soft 8's
Or these with 4.25 inch backspacing below
Crager Soft 8's 4.25
Crager Soft 8's
Thanks Rexm, Cherry, and Tibby. You guys never let me down on here.
@Tibby, the 2nd link you provided, I shouldn't have to file the calipers down should I?
Wouldn't mind the tires sticking out a bit but not to far out that I would need fender flares. Cops are picky about that in my area for some reason =/
in the link that i provided someone said they had to file them down a little with those rims. But filing them is as simple as taking your file and working on the rub spots. There isnt a risk of damage unless you go nuts with a grinder or something lol
Ok haha, well I know what I will be purchasing when I get my next paycheck....on the 27th : (
I don't know about your exposed tread laws up there. But we don't have any here, so that is why I recommended those. How far can your tires stick out before they get on to you about it? Either setup should have you with a more aggressive stance but only sticking out a little bit. Look at how much mine stick out then add a hair onto that. Those soft 8's are 15x7's and these Camaro wheels are 15x7's. The only difference is I have 4.5 inches of backspacing and you have 4.25 inches of backspacing. Yours will stick out just a hair more. But it'll look good and shouldn't bother the cops.
I am not sure about the limit here either. I LOVE the way blazers look with the tires sticking out, and I think it would like great with that second link you linked me. Yours looks awesome!
I guess that is what I will be going with, I will let you know if I end up getting pulled over : P. Thanks man
