What tire size is this?
Old Nov 23, 2006 | 04:11 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default What tire size is this?
When I bought my vehicle it came with almost brand new Hercules Terra Trac A/T tires on it. They look very aggressive and are very nice. Only thing is I dont know the size of the tire. I know the rims are 15's but no where on the tire does it say its size. On the tire it does say 235/75R15
Old Nov 23, 2006 | 04:17 PM
20Blazer00's Avatar
Default RE: What tire size is this?
235 tire diameter in metric/75 aspect ratio width R type of tire 15 size of the rim opening
Old Nov 23, 2006 | 05:35 PM
slammins15's Avatar
slammins15 is an unknown quantity at this point
x
Old Nov 23, 2006 | 06:08 PM
I think he's trying to determine what it is in inches...
Doing the math, 1mm == 0.03937in
So the width is 235mm * 0.3937in/mm = 9.252in
75 is the aspect ratio, or the ratio of width to sidewall height, as a percentage.
So H_s == Height of sidewall = 9.252*75% = 9.252*0.75 = 6.939in
Now we know it's a 15" rim, but to get the overall tire diameter, you must double the sidewall and add the rim width.
Overall Diameter = 15 + 2 * H_s = 15 + 2 * 6.939 = 28.878in Which rounds out to the accepted 28.9in outside diameter that is the 235/75R15 tire.
If you don't feel like doing the math or unit conversions, I found a nice java utility a LONG time ago that would do it for you. You can also compare tire sizes.
Tire Size Calculator
Old Nov 24, 2006 | 09:58 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Good job Kyle!.....this is a VERY common misconception:
The first number is the width in millimeters...not the diameter.
Old Nov 24, 2006 | 09:42 PM
swartlkk thank you so much. That was exactly what I was looking for, I really appreciate all you guys help. Thank you!
Old Nov 24, 2006 | 10:48 PM
Not a problem, that's what we're here for!!!
BackwoodsBogger14
Headers, Intake, & Exhaust
Oct 8, 2013 12:20 AM
smitty1244
Tires and Wheels
Dec 5, 2009 01:52 PM
mx_579
Tires and Wheels
Sep 18, 2009 11:36 AM
dshaw1
Tires and Wheels
Jan 21, 2006 02:41 PM
demjjm
Tires and Wheels
Oct 3, 2005 04:44 PM
