wheel bearing wear
Old Nov 11, 2008 | 03:02 PM
jessebasiuk's Avatar
jessebasiuk is an unknown quantity at this point
Default wheel bearing wear
ok i am looking at a new set of wheels and i found some i like and they fit no problem but i have been reading some posts and the backspaceing is 0 degrees and stock wheels are positive 6 degrees an my question is i know runing these wheels will wear out my wheel bearings but how quick would this be i am apprentice mechanic so its not too expensive for me to replace them but i only drive 7000 km a year (4300 miles) so how fast would i be replacing wheel bearings
http://fastwheels.ca/component/page,...art/Itemid,62/
there is a link to the wheels
Old Nov 11, 2008 | 05:22 PM
Default RE: wheel bearing wear
Those rims have an offset of zero which would mean that the back spacing would be somewhere around half of the rim width plus about a 1/4 inch (for the lip of the rim). So if you were looking at the 7 inch wide rim, the back spacing would be somewhere around 3.75".
Obviously it is not ideal and you would have to choose your tire size wisely as to not rub, but they should work.
Old Nov 12, 2008 | 08:52 PM
so what about a wheel bearing and if i was to buy these i am running brand new 235/70r15 would these tires rub wile at full turn and would they rub at full suspension compression.
Old Nov 12, 2008 | 11:26 PM
vin791's Avatar
vin791 is an unknown quantity at this point
they shouldn't rub at all what's stock backspacing? 5"? you might rub frame a little bitat full lock
brianp
Jun 1, 2020 10:30 AM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
flyinbrad
Sep 28, 2007 02:21 PM
kngflp
Suspension Tech
Nov 11, 2006 06:55 PM
