"Wheel" they fit?
Old Jun 28, 2013 | 11:36 AM
Steve-o's Avatar
Steve-o will become famous soon enough
Default "Wheel" they fit?
the wheels im looking at in a 15x7 come in 3.75, 4, and 4.25 backspacing. my question is which one will fit with minor fender rub while still sticking out a little. i plan on running the same size tire i have now which is 255/70/15. ATM i have factory 4x4 wheels with 1.5' spacers on and had next to no rub 5seconds with a hammer fixed the rub . and i have no lift, no cranked tbars, no shackles.
Old Jun 28, 2013 | 11:56 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Stock is 6" bs so 4" will stick out 2" further than stock and .5" further than what you have now with spacers. 4" bs is the most i would personally do.
Old Jun 28, 2013 | 12:14 PM
Jamaroon's Avatar
I'd go with the 4.25" BS. The Z28 Camaro wheels are 15x7 and 4.5" BS and IMO are the perfect BS for the blazers. The 4.25 will stick out 1/4" more than Camaro wheels
Old Mar 26, 2014 | 03:42 PM
Steve-o's Avatar
15x7
Backspacing (in):3.688 in.
Offset:-20.00mm
15x7
Backspacing (in):3.750 in.
Offset:-6.00mm
Size:15x8 Bolt Pattern:5x4.75 Offset:-27mm Backspace:3.44
how will these fit?
Old Mar 26, 2014 | 05:40 PM
El_Beautor's Avatar
I agree with Jamaroon that the 4.25 BS rims would be the better option. Not as much trouble with rubbing on the fender and less stress on the front hubs.
Old Mar 26, 2014 | 10:22 PM
Steve-o's Avatar
15x7
Offset:-20.00mm
15x7
Offset:-6.00mm
but how will these fair?
Old Mar 27, 2014 | 08:09 AM
Jamaroon's Avatar
Same question, same answer... go with the 4.25 BS, the rest will rub
Old Mar 27, 2014 | 09:38 AM
El_Beautor's Avatar
Originally Posted by Steve-o
15x7
Offset:-20.00mm
15x7
Offset:-6.00mm
I'm not trying to rant or rain on your parade. If you want to get them go for it. It's your money, and your truck. My personal opinion is that they're probably not a good idea. You might be able to run them but you'll almost certainly rub hard on the back of the front fender when turning unless you trim a good 2" section off. You'll also most likely hit the top of the fenderwell when you compress the suspension hard, either offroad or hitting speed bumps with a bit of speed. You'll be decreasing your backspacing by 2.5 inches which will cause significantly more stress on the front hubs. If you have quality hubs they might be ok, but if you have cheaper or older hubs you will likely burn them up quick. If you get 8" wide rims the tires will stick way out from the fenders (3.4" further than on stock rims) and depending on your local laws you might run into problems with that unless you put on fender flares or something else to protect them. Most areas have laws that govern this, it just depends on whether the police want to enforce them.
Old Mar 27, 2014 | 02:47 PM
Steve-o's Avatar
rubbing is what I don't want. I don't plan on building my blazer for offroad, I plan on buying a cheap truck soon to beat on instead of ruining my blazer
Old Mar 27, 2014 | 09:12 PM
99lsdriven's Avatar
99lsdriven is on a distinguished road
There is another guy on the forum that asked a very similar question. The lower the number is in inches for backspacing the more it will stick out, I have 15x8 with 3.75" BS and rub quite a bit, I'm not using any sort of oversized tires but my sidewalls are about 2.75" out from my fender. Z28 wheels are 15x7 with 4.5" BS and stick out 1.5"-2".
blazintexas
May 8, 2012 10:41 AM
Radar0066
Tires and Wheels
Jan 9, 2010 04:34 PM
JST4SHO
Tires and Wheels
Apr 13, 2007 10:26 AM
FImports
Tires and Wheels
Dec 9, 2006 12:12 AM
chevy4life
Tires and Wheels
Oct 31, 2005 09:59 AM
