wheel width
Old Jan 6, 2009 | 08:58 PM
jessebasiuk's Avatar
jessebasiuk is an unknown quantity at this point
Default wheel width
i got stock wheels and 235/70r15 tires and i want to reuse them a stock wheel is 15x7 and going to a 15x8 would there tires still work
Old Jan 6, 2009 | 10:10 PM
WolfPack's Avatar
Default RE: wheel width
Yep they'll work. Tire size should be within 4' or so of the rim width.
Old Jan 7, 2009 | 05:57 PM
Barc's Avatar
Barc is an unknown quantity at this point
Let me beat a dead horse...[sm=icon_beat.gif]
Many wheel sizes are in Standard (American) units, where your tires are in metric. Your size means that the tire is 235mm wide. The sidewall height is 70% of the width. The r means Radial, and the 15 is your wheel diameter. If your wheel is smaller than that 235 mm (about 9.3in) you should still be alright. The closer you get to that magic 235 the weaker your bead, if I remember correctly; and, your tire starts to look more triangular from the rim. Like this: /_\. In the future, if you're curious, just divide the first number by 25.4 and that'll tell you the width in inches. If It's bigger than your wheel, you should be good.
cntryboy081
Tires and Wheels
Mar 17, 2014 06:55 AM
tony991
Tires and Wheels
Jun 24, 2010 11:55 AM
speterson1011
Tires and Wheels
Oct 16, 2009 05:48 AM
Likwid
Tires and Wheels
Apr 3, 2006 03:50 PM
