wider tires
Old May 30, 2006 | 09:11 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Default wider tires
I currently have a '96 stock blazer 4x4 with the tiny little stock tires on there and I want a bigger look. I understand that 30 inch tires will fit a stock blazer but I only hear about 30X9.5 tires. Will a 30 inch tire but with a wider tread width fit? I was thinking something like 265/75 or 265/70. Would something like this fit or would I have to get new wheels? If I get new wheels how wide could I fit then?
Old May 30, 2006 | 10:26 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
Default RE: wider tires
check the link at the very top, Hanr3 went through a complete write-up on all the tire sizes that fit and wont fit. To answer your question, wider tread than a 30x9.5 will rub when turning, since the 9.5 will occassionally rub. Check the tire manufacturers website to get the specific width in inches, there are usually charts that give all the dimensions, there are differences between the listed size and the actual size. Ex: some tires that are listed as 30"s are only actually 29.5".
Old Jul 5, 2006 | 03:46 PM
p_j_robertson's Avatar
p_j_robertson is an unknown quantity at this point
But what is the widest tire that you can mount on the back of a 98 Blazer. I want to get wider tires on the back but to leave the size on the front as 75. I think that you can put 80's or something but not sure. Anybody have any idea how exactly to find out how wide the tire can get without modifications to the suspension
Old Jul 6, 2006 | 12:34 AM
Cow Killer's Avatar
Cow Killer is an unknown quantity at this point
i can get my 31x10.5's to rub the inner fender well and i got 2wd rims. 2wd rims = different offset
Benzesp
Tires and Wheels
Jun 6, 2013 04:14 PM
89 Blazer Lebanon
Tires and Wheels
Sep 8, 2011 11:47 AM
Darleen
Tires and Wheels
Jun 4, 2011 09:38 PM
littleman69
Tires and Wheels
Mar 4, 2009 07:07 AM
klote82
Tires and Wheels
Mar 28, 2008 06:56 PM
