Will BFG's fit
Old May 18, 2008 | 06:19 PM
drperry's Avatar
Default RE: Will BFG's fit
ZR2 rims are exactly the same as normal 4x4 S-series rims.
Absolutely no difference, other than possibly the year of your rig, which would make them look different... That's it.
Old May 22, 2008 | 01:39 PM
The A Team's Avatar
The A Team is an unknown quantity at this point
Ya i dont know what you guys are talking about the ZR2 rim is the same as all the Blazer 4x4 rims.
Remember ZR2s come factory with 31x10.5 obviously with no issues. But on a standard 4x4 all factory yo umay get some rubbing at full turn of the wheel, and with articulation.
My ZR2 had 32x 11.5 bfgs onit when i got it never rubbed once. Now i have 31s back on it with a -30 offset rim and it get rubbing.
With your factory rims i dont see much of any issues putting 31s on a standard 4x4.
Old May 22, 2008 | 05:10 PM
drperry's Avatar
On most 2nd gen two door non-Z Blazers, 30x9.5 R15 on the stock rims is the biggest you can go without rubbing, with no lift.
Old May 22, 2008 | 09:38 PM
WolfPack's Avatar
x2. ZR2s have larger wheel wells to clear bigger tires, so you very well may have cleared 32x11.50s fine, but I'm willing to bet you had a bit of lift from your torsion bars to clear them fine.
Also remember the safe rating is +- 4' from rim to tire. So a 10.50 will fit fine on a 15x7.
Old May 22, 2008 | 11:18 PM
The A Team's Avatar
What? ZR2 has the exact same wheel wells as every other blazer it is no differnet in the body besides the flares.
No my truck is 100% stock.
Old May 23, 2008 | 10:13 PM
NVANZEE's Avatar
ORIGINAL: The A Team
Zr2 are not the same. The wheel wells are bigger, i have measured them
Old May 23, 2008 | 10:34 PM
WolfPack's Avatar
x2
There's much more to a ZR2 than just 31s, flares, and a lift.
see here: http://forums.s-series.org/viewtopic...61d9f9aeed76b8
(nice pic of the frame too)
or here:http://forums.off-road.com/gm-small-...s-non-zr2.html
or here: https://blazerforum.com/m_98628/tm.htm
Old May 24, 2008 | 12:04 AM
The A Team's Avatar
Well ill be gone to hell/ [sm=smiley3.gif]
Old May 24, 2008 | 03:56 AM
drperry's Avatar
FYI, if you get a ZR2 axle under a reguler S-Series 4x4, the front/rear will line right up
Close enough, anyway, lol
Old Jun 1, 2008 | 02:43 PM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
I have 30x9.5 R15s on the stock rims and clears fine with full turns and flexing! I actually also have some questions about possibly going to 31"s. So my question is: What will rub if I get the 10x8 black steel rims with 4" back spacing and BFGoodrich A/T 31X10.5 R15? Also, if I get 10x7 rims wouldn't that make the whole wheel a little taller since it will squeeze the 31x10.5 R15s? If this post doesn't belong here, please delete it and I will start a new thread.
Thanks!
