Would these rims fit ?
Old Mar 2, 2018 | 03:19 PM
oakland73rd's Avatar
oakland73rd is on a distinguished road
Default Would these rims fit ?
Hey y'all I have a 4 door 93 S10 blazer 4x4 and I wanted to see if these rims would fit on my truck does anyone know they came off a maro ss and they have a bolt pattern of 5x120 ? I want these rims but don't know if they will fit in my truck
Old Mar 2, 2018 | 03:42 PM
chevyriders's Avatar
What did they come off of? Our trucks are 5×4.75(5×120.65) lug pattern.
Old Mar 2, 2018 | 04:42 PM
newguy's Avatar
5 bolt chevy rims, they should, but why?
Old Mar 2, 2018 | 05:12 PM
The majority of modern 5 bolt chevy wheels are not 5x4.75. Other than s series, f body, g body and corvettes up thru c6 are the only others that are the same lug pattern.
Old Mar 2, 2018 | 05:28 PM
On the post it says they came off a Camaro but bolt pattern is 5x120
Old Mar 2, 2018 | 06:03 PM
newguy's Avatar
Did not know that, Thanks!
Old Mar 2, 2018 | 06:05 PM
Yeah the newer style camaros are 5x120. Our trucks are technically 5x120.65. That .65mm- while not a lot- is enough to put significant linear pressure on the lugs when tightened. That can and has led to people shearing lugs.
No problem newguy, glad to pass the info along.
Old Mar 2, 2018 | 07:43 PM
Would it work if I used spacers if that is even possible and if
it is possible what size spacers ?
Old Mar 2, 2018 | 08:44 PM
You could use adapters/spacers, 1.25" is the minimum you can run without having to trim your lugs, so that's what I would go with. Depending on how tall/ wide the tires are you could end up with your tires rubbing the fenders.
tibby
Tires and Wheels
25
Aug 15, 2012 05:45 PM
a2dadamm
Tires and Wheels
Feb 5, 2012 08:01 PM
xJakeLIKEShisBLAZERx
Tires and Wheels
Sep 10, 2011 12:50 PM
panthersfan101
Tires and Wheels
Jan 17, 2010 12:20 PM
flowmasta
Tires and Wheels
Aug 10, 2006 11:58 AM
