If you have $100 to spare, I'd buy them anyway. I know BlazinJason in Canada has been looking for a cheap set. If they're close to you maybe you could work something out with him?
I've seen them painted black before on a blue 4 door Blazer. Looked pretty sharp. I'll see if I can find the pic. 265/55/17 would be pretty close to stock tire size in a 17" tire. |
Originally Posted by TripleBlackBlazer
(Post 473331)
If you decide not to use them, and want to pass them on, holla!!!
Tibby, I just picked up a set of those Camaro rims this weekend too! I was considering painting the insides glossy black and keeping the face the satin silver. I'm probably going to grab a set of used 265/70/17's off Kijiji for now since money's a bit tight. I may have to trim a bit to squeeze them in, but I clear my 31x10.5's fine. The BFG AT's i have on now seem to be a taller 31 so hopefully it doesn't take too much.
Trippleblack, did you have any issues with these rims having more than 6" backspacing? If I'm measuring right they have closer to 7" backspacing. |
I did have to trim and I do rub frame at full lock. I still have a set of ZR2 t-bars waiting to go in from forever ago and I think that will solve some of the frame rub. If not I may put a 1-1.25" spacer up front.
(Post 535102)
Tibby: Have you picked out tires yet? Chances are I'm just going to end up with some basic factory take-offs unless I get really lucky. I'm hoping since 265/70/17 is such a common size I might get lucky and find a good deal. |
IIRC, tibby never ran the rims because he rubbed sway bar and didn't want to chance making a hard turn and flipping. At least that's what I think he said.
(Post 535112)
I think I'll be ok. I have 1.25" spacers on the front, and a ZR2 axle out back so I'm already wider than stock. I think I should be ok. I'll post up results in my build thread once I get some tires on them. I wish I could steal the ones of my Durango. I've got 265/70/17 Cooper Zeon LTZ's on there and they are awesome. I absolutely love them.
(Post 535129)
