Your opinion on painting hub caps?
Old Feb 15, 2013 | 07:34 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
Default Your opinion on painting hub caps?
So I plan on painting some old stock 4x4 rims(15x7) semi-gloss black with a gloss clear or metallic clear coat.
Now for the center cap, see below.(recently washed)
Should I also paint these to match or would you leave them?
They looked okay on the other stock black rims(15x6) I have but those were faded and not in the best condition so it matched. I looked a bit closer at the inserts and I think they look fine and I will just tape them off. Side note GM wants $33.42 each for the insert.
Attached Thumbnails Your opinion on painting hub caps?-img_20130215_192629_zpsf65e1d61.jpg
Old Feb 15, 2013 | 08:08 PM
ChevyBlazerChick's Avatar
Coming from someone who has painted just about everything on her truck... DO ITTT.
Plus you wouldn't want shiny like new rims and faded center caps.
Old Feb 15, 2013 | 08:49 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Clear em. This is what I use for small jobs.
2K clear coat: Spraymax
Old Feb 15, 2013 | 09:18 PM
Karcinagin's Avatar
Thanks for the link I will look into it, and see if its sold locally.
I will actually be using a paint gun as the paint is cheaper and should be faster so rattle cans are out. I'm thinking on going for just a gloss clear coat as the metallic is a bit touchy to get right and keep clear so I have read.
So after 6 hours of work I have everything primed.
How they started out as
Post sand blasting
After primer
Attached Thumbnails Your opinion on painting hub caps?-img_20130216_110509_zps29ce7172.jpg   Your opinion on painting hub caps?-img_20130216_165630_zpsc0126771.jpg   Your opinion on painting hub caps?-img_20130216_164820_zps5e6942a3.jpg   Your opinion on painting hub caps?-img_20130216_152057_zpse5279b71.jpg   Your opinion on painting hub caps?-img_20130216_110438_zps9e57cba1.jpg
NVANZEE
Jun 16, 2009 08:14 PM
Chevy Lover
Mar 6, 2007 11:56 PM
rabbit0102030
Jan 30, 2007 05:35 PM
nofear17bmx
Dec 20, 2006 04:58 PM
blazin97
Nov 7, 2006 05:32 AM
