zq8 wheels
Old Aug 24, 2007 | 10:21 AM
lldjr's Avatar
lldjr is an unknown quantity at this point
Default zq8 wheels
Does anyone know if these ZQ8 wheels will fit a 1983-1994 blazer 4x4 ?
I have been told that they will only fit a 2wd....and I have been told they will fit a 4x4.
So which is it ?
Dimensions : 16x8, 4.25 backspace, 4.75 bolt pattern
Pilot hole diameter = ?
Any input will be appreciated.
Thanks
Old Aug 24, 2007 | 11:42 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: zq8 wheels
they will bolt on but will stick out about 2 inches farther than your current rims...
Old Aug 24, 2007 | 01:47 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Yeah - if they fit a Camaro or Corvette, they will also fit your Blazer. If it's a 4x4, then they will stick out, and you may even havea problem with the caps on the front. However, they will still fit.
Old Dec 20, 2007 | 03:20 PM
cain45's Avatar
cain45 is an unknown quantity at this point
Anyone know the GM part # for the wheel above?
ZQ8 Blazer
Jul 3, 2019 05:29 PM
Geezert
Aug 25, 2010 12:15 PM
1998blazer
Lowering Tech
Feb 7, 2009 03:51 PM
Logan
Tires and Wheels
Jan 11, 2008 10:47 AM
