do signatures do anything?
so I saved the Sig line with my truck model and stuff but I've never seen mine or anyone else's signature line in any post anywhere. how do I see those aren't they supposed to come up after every post at the bottom?
I thought that by default, that if you make and save a signature, it should start posting it to the bottom of your posts. I'm not sure that there's an option to turn it on or off, you just either have something in your signature or you don't.
There IS an option to turn on and off that allows you to actually see signatures though.
Go to the "User CP". Under the "Your Control Panel", in "Settings & Options", and "Edit Options". About 2/3 of the way down there's a section for "Thread Display Options", and within that there's "Visible Post Elements". There you'd find a box for "Show Signatures". Make sure that it's checked.
I have a simple link to my build thread as my signature; is that not showing up for you?
thanks for all of that I got on the main page to do all of that. otherwise normally I only look at the mobile site version. I do see your threads come up at the bottom of your post but I still do not see mine....so can you see my Sig line about my bravata and its motor and specs?
