Bad Oil leak and oil pressure problem
Old 12-30-2012, 05:11 PM
Kaser1026's Avatar
Kaser1026 is on a distinguished road
Exclamation Bad Oil leak and oil pressure problem
I have a 91 4.3L it has a bad oil leak. It is coming from driver side around oil pan. It started as a drip now it is more of a constant stream. Not a mechanic there are 2 hoses that run along it. Not exactly sure what that part is. But the oil is leaking right around those 2 hoses. Could they have anything to do with it? Any advice will help out a lot. Also oil pressure gauge jumps around
Old 12-30-2012, 05:17 PM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
Its going to be the lines,or the paper gasket/ and oring on the housing the lines run into. pressure wash the area clean,and let it run and watch for the leak
possibilities :
1. If its seeping around the adapter (where the 2 oil lines run into) its just a gasket,and a oring that needs replaced.
2. if its leaking from where the lines run into the adapter,its just 2 small orings. (one on each line. might as well replace both of em?)
3. another culprit could be the actual lines. look at where the black hose runs into the metal part of the lines (where its crimped together) they leak from there too. you gotta replace the whole lines then.
Old 12-30-2012, 05:22 PM
Kaser1026's Avatar
Thank you. Would that cause oil pressure to jump around too? Sorry I am not too good at figuring the things out. I can just fix it once I figure it out.
Old 12-30-2012, 05:24 PM
chris015's Avatar
ehhh. maybe. if the leaks bad enough. (streaming out). Is the gauge steadily moving around or is it popping really fast?
Old 12-30-2012, 05:26 PM
Kaser1026's Avatar
It jumps around more when driving. Sometimes it will just bounce back and forth. And at times you give it gas and it drops to zero
Old 12-30-2012, 05:29 PM
Kaser1026's Avatar
That's what had me thinking oil pump but I didn't know for sure where it'd leak if it was
Old 12-30-2012, 05:34 PM
chris015's Avatar
if it flicks really fast then id try replacing the sending unit (driver side,beside the distributor). Do that before spending big money and time on other things.
Old 12-30-2012, 05:43 PM
Kaser1026's Avatar
Thank you i will have to check it all out tomorrow! Hope it is something simple.
Old 12-30-2012, 05:50 PM
chris015's Avatar
keep us updated
by the way,the gasket set you need for the leak if its not the hoses is
Dorman part # 82560. Give the clerk that part # and tell them its a gasket set for a oil cooler.
Old 12-30-2012, 05:58 PM
Kaser1026's Avatar
Awesome thanks a lot. I looked up prices for everything. Not too bad. I appreciate the help
Blazer98guy
11-14-2013 10:34 PM
wazzledoozle
03-24-2011 06:39 PM
mtz57
08-21-2010 10:10 PM
rohde782
10-08-2009 08:36 PM
Quick Reply: Bad Oil leak and oil pressure problem
