1994 chevy S-10 blazer 4x4 transmission fluid capacity
Old 10-15-2010, 08:05 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default 1994 chevy S-10 blazer 4x4 transmission fluid capacity
I just changed my transmission filter and only have a chiltons for 83-93 and it says 4.4 pts, is that right for the 94 and how many quarts is that? Or just tell me how many quarts is recomended for a 94 4.3 vortec engine w. Thanks
Old 10-15-2010, 08:40 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
I'm pretty sure you need 4 qts, not 4 pints. And I'd have 5 qts on hand, just in case.
Old 10-16-2010, 08:55 AM
Thanks, I will put the rest of the gallon of fluid in there. I was getting a reading or what looked like a cold reading but it's just easier to know about how much it needs.
Old 10-16-2010, 09:01 AM
You need to check the level on the dipstick first. Then warm it up to operating temperature, running it through all the gears. Then check the dipstick again. Be careful to get the level right - overfilling is as bad as underfilling.
Old 10-16-2010, 09:03 AM
I did a cold check and I went through all the gears and then let it idle for 3 min then checked it. Do you have a chiltons you could check real quick to comfirm the fluid capacity?
Old 10-16-2010, 09:12 AM
According to the factory service manual, drain and refill (filter change) is 5 qts.
Old 02-17-2011, 11:47 AM
rastoma's Avatar
rastoma is on a distinguished road
Did you have to remove the cross member near the end of the transmission to get the pan off?
Old 02-17-2011, 04:05 PM
ffox's Avatar
ffox is on a distinguished road
The 4.4 pts. is for a 5 speed transmission....
irondooks88
06-21-2010 03:58 AM
republic
10-12-2009 04:58 PM
TAZ454
02-01-2008 02:57 AM
corr33
10-31-2007 06:59 PM
KennyJonson
12-26-2006 06:09 AM
Quick Reply: 1994 chevy S-10 blazer 4x4 transmission fluid capacity
