2002 trailblazer dome lights
Old 07-12-2008, 09:11 PM
mboggess's Avatar
mboggess is an unknown quantity at this point
Default 2002 trailblazer dome lights
Dome lights do not work....fuse is not specifically labeled to check, have tried pushing overide button, need help.
Old 07-12-2008, 11:44 PM
WolfPack's Avatar
Default RE: 2002 trailblazer dome lights
What is making you say they don't work? Do they just not come on when you open the door? Or when you flip the switch? Orrr what? The bulb could just be burnt out, or, you could have a bad door switch if they're not coming on at the right times...OR you could have a broken (or just you've pushed it) dome override button that's keeping them off.. more info!
Old 07-13-2008, 11:36 AM
mboggess's Avatar
doubt it is a bulb unless they all went out at the same time (dome lights), I wouldnt think it was a door switch since it is all of them. guess the overide switch could be broke but it does cut off the day running lights when pushed four times. they dont come on when I open the ddor, turn the dimmer switch, push the keyless entry, NONE! I am trying to locate which fuse they are on or any other possible solutions.
Old 07-13-2008, 05:51 PM
Do any of your courtesy/reading lights work when you turn them on manually (above each door)?
Old 07-13-2008, 11:40 PM
mboggess's Avatar
yes, the ones you push to turn on work when pushed, the ones right beside them that are supposed to come on when the door opens do not work.
Old 07-16-2008, 09:00 PM
hoodsblazer is an unknown quantity at this point
all doors?
JohnBarJB
11-27-2012 10:28 PM
contour1
04-14-2012 02:20 AM
cragpretzel
11-28-2006 11:52 PM
RQuickDraw
10-27-2006 09:38 PM
98BlazerLS
01-06-2005 10:37 PM
Quick Reply: 2002 trailblazer dome lights
