96 Blazer No Start, No Power to OBD Port or ECU
Old 09-14-2010, 10:40 PM
1579's Avatar
1579 is on a distinguished road
Default 96 Blazer No Start, No Power to OBD Port or ECU
Hey Guys,
Im new to the forum but not to 4x4s . Hopefully you can help me out
Im trying to figure out if there is a main power relay to the ecu on a 96 Jimmy 4.3. Seems the one Im working on has no main engine power, when i turn the key to run I get no warning lights, which leads me to believe that the ecu isnt getting power. Am I on the right track? Obviously the truck wont start and it has no injector pulse, no spark, no nothing.
Wiring diagrams or a main relay location would be great. I tried checking fuses and swapping some of the relays around.
Thanks in advance!
Brandon
Old 05-06-2012, 12:48 PM
gotlandia's Avatar
gotlandia is on a distinguished road
Hi.
Did you solve your problem?
I have the same on my 1997 Blazer.
Old 05-06-2012, 08:40 PM
boomin_brava's Avatar
boomin_brava is on a distinguished road
I have the same problem. My 98 bravada does this randomly when i shut it off and go to start it again. No cluster lights or anything. Only the batt. Light shows. Then randomly all the warning lights come on and it starts right up.
Old 11-27-2012, 06:44 AM
**moonshine**'s Avatar
**moonshine** is on a distinguished road
Same problem here, no cluster lights = no start, but cranks, sometime the cluster lights works and then it starts, sometimes hitting the top of the dashboard makes the lights to come on and then it starts...
Anyone got a ide, going out now to rip it apart.
it's a Blazer 1997 125000 miles
Old 11-27-2012, 06:53 AM
spittybays
Guest
Posts: n/a
Go to the google search box on the on BF home page and type ignition switch
Old 11-27-2012, 09:15 AM
Thanks it was indeed the ignition switch that was at fault, if i tap on it its starts working.
Old 11-27-2012, 11:20 AM
Diaita's Avatar
Diaita will become famous soon enough
mine was ignition switch as well. it would crank til the battery was dead, but if i bashed the steering wheel, all the lights would come up, and it would start like normal.
Old 11-27-2012, 12:29 PM
rriddle3's Avatar
*Closing old 'threadjacked' thread*
rowe
22
12-10-2018 10:45 AM
matt4x4
04-24-2015 08:01 AM
billfrank85
07-18-2013 07:59 PM
pkrawetz
10-01-2009 10:38 PM
88blackzcand95blazer
Engine & Internal
14
01-24-2009 07:15 PM
Quick Reply: 96 Blazer No Start, No Power to OBD Port or ECU
