99 Blazer Turns Over But Does Not Start (any ideas?)
I have a 99 Blazer 4 door 4wd and I replaced the blower motor a few days
ago, my blower stopped working again and so I checked the blower resistor.
The blower resistor was bad so I replaced that and now it blows air but it will
not start, I do not hear the fuel pump when I turn the key on.
any ideas?
any ideas?
Check the basic stuff first: fuses, both places, battery terminals and connections.
Do you have a voltmeter? If so, you can check the fuel pump test terminal for voltage with the key on; report your findings and then we can go from there.
If it is turning over like it should then your either getting no fuel or no spark. To check the spark plug simply pull it out and set the tip or threads on something metal and have someone turn it over, if it sparks you obviously got fire. To check the fuel pump turn the ignition on (don't crank) and you should hear a whinning sound coming fuel tank. If you don't then take some gas in a small cup and pour down your throttle body and try to crank it...if it cranks=bad fuel pump.
When's the last time you changed the fuel filter?
I have the same problem, it cranks but doesnt start, it happened a few times in the past several months but usually started and acted normal the next day for weeks/months. Now it wont start at all, I thought it was the ICM, I swapped it out from my moms blazer, hers started with my ICM in it, and mine still doesnt start. I'm guessing its the coil, rotor, or the distributor itself. The fuel pump and filter was replaced last year when my Dad owned it. Any ideas? I have a new cap, rotor, wires, and plugs for it but I dont want to do all that work and still not have it run (or start for that matter). Oh and a month or two ago I replaced just the cap thinking that was the problem, it worked for a few weeks as said before but it still has that problem. Any suggestions would be appreciated, thanks!
Put a AC Delco cap and rotor on it. I had intermittent crank no start replaced fuel pressure regulator still had same problem, replaced fuel pump same problem, replaced spider with Delphi MFI same problem but it did run much better when it did start but I took off old NON AC Delco cap it had lots of corrosion but was only on there 2 years. Ive read on here about using only AC Delco and also the techs I know say that has fixed more intermittent no starts and swear by them just like Capt Hook and Swarrt. By the way these loan a tool fuel pressure testers at parts stores are pure crap they leak down or show the wrong readings so don't depend on them!!!
Just because the fuel pump was replaced does not mean it isn't the problem. You should start with a fuel leakdown test to rule out the fuel pump. What brand fuel pump did you put in? If you look around the forum you will see that many times the problem was a fuel pump that had been replaced with an off brand. It seems to happen over and over. You have to use either Delco or Delphi fuel pumps. But still, do the leakdown test first.
javaholic
03-01-2011 07:33 PM
