Blower motor heat working not working
Old 12-06-2010, 04:14 PM
bootlegger's Avatar
bootlegger is an unknown quantity at this point
Default Blower motor heat working not working
I have a '97 Blazer 4 door. The blower motor (when working) starts out strong and over a period of 35 minutes slowly fades out to eventually not working. I tried pounding the dash and that didn't work. Every once in a while if I hit a bump it will go back on but most times it does not. Anyone know of a solution? I am thinking there is a loose wire somewhere?
Old 12-06-2010, 04:16 PM
If the blower motor doesn't work on any speed, it likely is worn brushes in the blower motor itself. If this is the case, the motor likely needs to be changed.
Old 12-09-2010, 01:29 AM
itsmeuherel7's Avatar
itsmeuherel7 is on a distinguished road
same truck same problem it is the blower motor
Old 12-10-2010, 10:20 PM
michelle's Avatar
michelle is on a distinguished road
I had this same issue for some time. Check your ground wire on the fire wall coming from the blower motor
Old 12-14-2010, 05:18 PM
Lowrd96Blzr's Avatar
Lowrd96Blzr is on a distinguished road
Default HELPP. no heatt, cold here. lol
Im having the exact same problem, Comes in then goes out, hit a bump, comes back in. Now it quit working all together. I was wondering if you could tell me how to test it to make sure it has power? where is the ground wire on the firewall so I could check that?
maxvamp
10-31-2020 08:19 AM
tcheche
06-21-2012 08:46 AM
mattman
06-20-2012 09:12 PM
swact
10-05-2010 02:55 PM
mxrider812
12-06-2009 03:32 PM
Quick Reply: Blower motor heat working not working
