Coolant and Tank Hose
Old 11-26-2007, 01:33 PM
jbreno's Avatar
jbreno is an unknown quantity at this point
Default Coolant and Tank Hose
After doing a search here, I found this thread, but the correct answer was not clear...
https://blazerforum.com/m_68378/tm.htm
The hose shown is this picture was not connected to anything. Is this an overflow, or should it be connected to my radiator? There is some fuild left in the tank, but it is not much. Certainly not to the "hot" level line.
Can someone please help?
[IMG]local://upfiles/7420/B942A587C7F14E1687E430CED609F7E8.jpg[/IMG]
[IMG]local://upfiles/7420/D543260DDC0747AF85F32C3308898F97.jpg[/IMG]
Old 11-26-2007, 01:54 PM
Default RE: Coolant and Tank Hose
That hose is the vent/over-flow and should terminate somewhere down near the frame rail. If you follow the hose attached to the radiator right next to the cap, it should connect to the overflow tank.
How is the level of coolant in the radiator? If the radiator is low, it is possible that the radiator cap is bad. Even if it is at the proper level, a replacement cap is good preventative maintenance.
Monica Joplin Mitchell
02-13-2013 09:24 AM
86TransAm
14
12-13-2011 07:46 PM
wjdjake
07-17-2011 02:06 AM
rob1621
04-03-2008 08:55 PM
ratwell
12-16-2007 09:50 AM
Quick Reply: Coolant and Tank Hose
