Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Closed Thread
LinkBack Thread Tools Search this Thread
Old 08-10-2009, 03:08 PM
taloka's Avatar
taloka is on a distinguished road
Default Heat/AC only blows through defrost
I have a 96 Blazer and the heat and A/C only blow through the windshield defrost vent no matter what position the heat/air switch is in. Someone told me it was a vacuum line problem but I don't know. I didn't know if there is a door somewhere that is not switching properly. Just need an idea as to where to start looking.
Thanks.
Old 08-12-2009, 03:35 PM
Rhodes19 is on a distinguished road
Most likely it is a vacuum problem. I just fixed a similar problem with my oldest daughter's Jeep. Now I will be doing some ac work on my youngest daughter's blazer. You should be able to follow the vacuum line from the engine, through the firewall, and to the mode selctor switch (ac, defrost, heat switch). It will be easiest to check the vacuum line in the engine compartment first and if its ok. Go to the mode selector switch next and see if you are getting any vacuum there. If you do get a vacuum to the switch then you may have a bad switch. If there is no vacuum at the switch then you will have to trace the vacuum line to the firewall. HTH
Old 08-13-2009, 03:58 PM
taloka's Avatar
Thanks for the info. I didn't realize that the vacuum line had anything to do with the switch. I had heard that but not being much of a mechanic I didn't know. Thanks again.
Old 08-14-2009, 12:02 AM
mchap87 is on a distinguished road
i had the same problem with my 95 blazer. It turned out to be the vac line at the back of the upper manifold was unplugged. It was a easy fix for once.
Old 08-16-2009, 11:07 PM
1996 Chevrolet Blazer
stapler2025 is on a distinguished road
Send a message via AIM to stapler2025 Send a message via MSN to stapler2025
Had this same problem on my '96, just fixed it today.
The vacuum line was actually rubbing against the manifold, and had scorched a hole thru the tubing, not to mention all the vacuum lines are shot anyway.. Now they're all replaced and it works tons better
Yay for ventilation again
Old 08-17-2009, 03:12 AM
jcws6 is an unknown quantity at this point
More Info:
If it's a "door" problem, the air generally doesn't blow through the defrost on all settings. When I had a problem with my air door, it was only on the "floor" setting. There are 3 "zones" for air output: upper (defrost), central (main vents), and lower (floor). If all "zones" are affected, it's generally a vaccuum which affects all of them. Defrost is the failsafe - it opens so the air goes somewhere, even if the system doesn't work.
Closed Thread
Tags
ac, air, blazer, blowing, blows, chevrolet, chevy, conditioning, defaulted, defrost, defroster, heat, s10, switch, vent, vents, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
