heater blend door acuator
Old 10-24-2007, 06:15 PM
whiskey24's Avatar
whiskey24 is an unknown quantity at this point
Default heater blend door acuator
I have a 1998 blazer with the computer climate control.I have no heat, i have narrowed my problem down to the electricacuator motor for the blend door.only time acuator moves is when you first turn ignition on it will turn all the way right(open door) then all the way left (close door) then thats it it will not move no more unless you turn ignition off then back on.any help would be appreciated thanks
Old 10-26-2007, 08:29 PM
Bobstar is an unknown quantity at this point
Default RE: heater blend door acuator
I had that happen on my 1996 Pontiac Bonneville. The part was only 80 bucks, but it was 400 to have the dash torn apart to get to it. I didn't do it because the actuator door was right behind the air bag in the pontiac.
Maybe you can get to yours from the glovebox. Good Luck.
sacrosuchus
11-15-2012 03:59 AM
hcii
11-27-2010 05:53 AM
monti72
04-25-2010 12:15 PM
armour1111
08-28-2009 05:21 PM
ABN31B
05-26-2009 08:12 AM
Quick Reply: heater blend door acuator
