New engine, leaking coolant from spot with no coolant
Old 03-04-2010, 02:18 PM
Skeeter Cruz's Avatar
Skeeter Cruz is an unknown quantity at this point
Default New engine, leaking coolant from spot with no coolant
Hey guys. 1998 Blazer 4 door 4x4. Just put a new engine in it from jasper. it's leaking coolant somewhere around the driver side exhaust. drips down onto the front axle differential and then the floor. don't think it's coming out of the temperature sensor, it's dry all around there. not a hemorrhaging leak, more of a fast drip.
Anybody know where it can be coming from? is there a loose tube in there I can't see? or does anybody have any general tip/tricks/magic formulas for fixing (or finding!) coolant leaks?
Thanks!
Old 03-04-2010, 02:56 PM
ZR2nut's Avatar
ZR2nut is an unknown quantity at this point
If it is leaking around the exhaust manifold you may have a cracked head!
Old 03-04-2010, 04:41 PM
Hope that's not it, don't know how I could have cracked the head without ever getting it out of the garage!
Any input on how to check that out?
Old 03-04-2010, 05:03 PM
awe341's Avatar
awe341 is on a distinguished road
It could also be a leaking lower intake manifold gasket. Probably incorrectly sealed at the factory when the engine was rebuilt.
Old 03-04-2010, 06:36 PM
LRV31's Avatar
LRV31 is on a distinguished road
Maybe leaking from a freeze plug on that side of the block? As for finding the leak they make a dye that goes into the system and using a blacklight the dye glows so you can see where its leaking from.
Old 03-04-2010, 06:38 PM
That's genius! I'll look into it.
Keep the ideas flowing if there's more out there.
Old 03-04-2010, 07:07 PM
ChrisC's Avatar
ChrisC is on a distinguished road
Also look at the exposed headstuds while the engine is running. They might be seeping, since this is a rebuilt engine. If so,
that means you'll have to pull the valve covers and check for pooling coolant.
DesertStorm
05-05-2014 12:26 PM
bigdaddykane93
12-22-2009 12:03 PM
amazinnblazin
07-16-2009 04:52 PM
CHEVY_ON_DUB_DUECES!
05-08-2008 11:45 PM
bm4183
02-20-2007 04:46 AM
Quick Reply: New engine, leaking coolant from spot with no coolant
