350 with a 4L60E transmission
Yeah I believe you should have a 4L60 with a kickdown cable rather than the 4L60e which diata already noted as the electronic version. If that's the case and you are trying to mount a carbureted 350 to it you should be ok as long as you hook up the kick down cable. Like big said you may need a different flywheel and possibly torque converter. If you do indeed have the e then you will need a newer injected motor and computer programming and such to get it all to play nice. Do some searching online and you will find alot!
dj00140
22
11-04-2015 05:03 AM
tech180
02-02-2013 10:23 AM
an240172
09-07-2009 02:58 AM
95blazer8620
10-19-2007 01:26 PM
