Blew out transmission coolant line
I decided to take my 1999 Blazer for a drive to work this afternoon. Just around the corner I noticed a smell and what looked like water from behind me. Once I realized it was was transmission fluid I quickly pulled over and shut it down. I noticed the transmission was slipping and once I popped the hood I found the upper coolant line going to the radiator had popped off spraying fluid everywhere. I reconnected the line and attached the plastic support piece over the clip. All should be well with the line now. It took about 6 quarts of fluid. I am heading out for a 2 hour drive up north tomorrow. Should I be worried? It feels okay but can't tell if it's hitting all gears. Thx!
I noticed within a few minutes. I came to a stop, accelerated to notice the transmission wasn't pushing the blazer like it should. When I noticed the trail of fluid and a couple puddles from stop and go, I parked it and shut it down. I would say the distance was less than an 1/8th of a mile if not less while it was leaking a trail.
wonder why it popped out. make sure that clip is ok and theres no crap in there preventing it from seating properly. if it popped back in easily, give it a few tugs backwards to make sure its secured in there.
if you wanna be paranoid bring some extra trans fluid for your trip
The clip was okay. I'm certain the problem was due to the plastic retaining clip was not seated properly after I installed the new radiator. I didn't think it would've made that much of a difference but it did. All is well now. I put a bit of tension on the metal clip so it would snap in/on tighter and got the ring completely seated over it. I pulled on the line to really make sure. The two hour trip was okay aside from an out of balance tire that would shake the blazer at random speeds between 65-75.
Blazed performance
12-13-2014 11:05 AM
chris015
04-08-2012 02:12 PM
shotnva777
46
10-12-2011 09:07 PM
