motor acting up after head gasket blown and replaced
Old 11-12-2012, 11:33 PM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
Default motor acting up after head gasket blown and replaced
im starting to think i should have dropped the gas tank because im having starting problems.. my blazer was parked for about 5 or 6 months work motor work.(head gaskets) it starts and will stay running for a sec or two and then shut off.. i will have to do this about 5-6 times before it will stay running. while im trying to start i could put my foot to the floor and it dont do a think no change at all! when it is running at idle its not ruff but if i give it gas fast it want to cut off.. im thinking bad gas but i filled up with super the other day so thats kinda going out the window and im scared to think its other things.. sorry for the long message.
Old 11-13-2012, 01:05 AM
97cherryblazer's Avatar
97cherryblazer will become famous soon enough97cherryblazer will become famous soon enough
Does it run crappy when it starts then dies? What does it do when it dies? Cuts right off or sputters?
Answering those questions will help us. One thing that comes to mind is the TPS, Look up on here how to check the TPS because to me it sounds like its not working right. Also, have you checked your fuel pressure? And lastly do you have any check engine lights?
Old 11-13-2012, 10:51 AM
sometimes it will run fine and cut off and sometimes it will run crappy(sputtering) and cut off. i dont know if any kight is on because someone before me took the light out. i havent checked fuel pressure dont know how i would and im not sure what TPS is but will look it up.
Old 11-13-2012, 02:45 PM
Go to a parts store and rent a fuel pressure tester. The test port is on the fuel lines running into the back of the intake. It should be 60+ PSI with the key in the run position and the engine OFF then it should not drop below 50-55 PSI after 10 minutes. Do you remember if you took out the spider when you did the head gasket? If you did you may have damaged a line and it could be leaking.
The TPS is the Throttle Positioning Sensor. It is located on the drivers side of the throttle body. There are two sensors there, one is the TPS and one is the IAC (Idle Air Control). You need a volt meter to test the TPS.
Old 11-13-2012, 06:18 PM
ok thanks buddy i will try these things
Old 11-13-2012, 07:27 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Any big vac leaks?
Old 11-13-2012, 08:35 PM
Originally Posted by Joshs4x4
Any big vac leaks?
to be honest i have no clue.. im taking it to the shop before the end of this week.. thanks guys for the help tho.
Old 11-13-2012, 09:36 PM
Joshs4x4's Avatar
Keep us posted
Old 11-13-2012, 10:05 PM
will let you all know any news that i get.
limited edition 1
01-27-2023 11:07 AM
J.R. Clay
03-17-2011 08:22 PM
dixie1864
11-20-2010 12:36 PM
MaineBlazing88
08-04-2010 02:12 AM
bigt
02-03-2007 09:10 AM
Quick Reply: motor acting up after head gasket blown and replaced
