Emergency flashers not working!!
Old 12-06-2006, 08:48 PM
kristaandbrian's Avatar
kristaandbrian is an unknown quantity at this point
Default Emergency flashers not working!!
I have a 77 Blazer used for plowing snow...first year to have this truck. My emergency flashers will not work. My turn signals still work. Checked all the fuses under dash. Does anyone know if they use the same flashers unit for both turn signals and emercency flashers or guide me in the right direction. When I turn the flashers on both turn signal indicators light up but no flashly lights outside on the truck...Thanks for any help and glad I found this forum.
Ohh and by the way...all other lights work properly....turn signals, running lights, brake lights, headlights.
And I have not altered the trucks wiring with my plow....All I have extra is a set of top mounted hella's with a relay going to a toggle switch inside so I can see when I plow.
Thanks again
Old 12-06-2006, 08:53 PM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: Emergency flashers not working!!
this is probably a stupid question but have u made sure all ur bulbs are in good condition and not halfway burnt out.
Old 12-06-2006, 08:57 PM
No question is a dumb one....but yes Ive checked all bulbs. Replaced two of them when I bought truck because running elements were burnt out. Thanks!
Old 12-07-2006, 01:21 AM
Chevy Lover's Avatar
You have 2 signal flasher units....one for the signals and one for the emergency flashers.
They should both be located close to each other on the fuse panel
big_charms@hotmail.com
03-20-2014 10:26 PM
Greghshepherd@yahoo.com
02-23-2012 01:15 AM
jlitzner
08-16-2011 03:07 AM
lafd55
03-06-2007 09:57 PM
Chrisat55
01-02-2007 12:58 AM
Quick Reply: Emergency flashers not working!!
