fuel not getting to throttle body
I have an 89 with the 350TBI engine. It will not start, no fuel. I have already changed the relay and fuse, but still not getting fuel. When i turn on key, i cannot hear the pump running. Is there any other electrical type things i can check before i pull the tank to replace the pump?
thanks
thanks
one of the ghetto ways of checking the fuel pump is lay under the truck and hit the tank with a big rubber mallet as someone cranks the engine. we do that all the time at work so we dont have to push the fuel pump job into the shop
ok, i have replaced the pump, fuse, and relay. I am not getting power to fuse, still not starting. when i turn key on to check for codes, i am getting no lights in dash area. I am thinking it might be the ignition switch. Any advice would help a great deal, it is now hunting season here and this is the only rig i have to hunt with.
blazerowner2011
08-02-2011 07:52 AM
johnb
07-10-2011 10:13 AM
LO3671
04-03-2010 03:53 AM
