NP203 Only Took 3 Qts
Old 05-02-2014, 04:17 PM
misweetrevenge's Avatar
misweetrevenge is on a distinguished road
Default NP203 Only Took 3 Qts
So from what I read before I drained my 203, you drain it from one of the 2 bottom bolts on the same side as the fill plug and then it takes 5 quarts to fill to the bottom of the fill hole.
I drained it until it stopped coming out of the bolt hole and started to fill it but it only took 3 quarts and then started flowing out of the fill hole. Am I supposed to drive it a little and then top it off? Or should it take the full 5 right away? Did it drain completely?
Old 05-03-2014, 08:07 PM
abig84's Avatar
if its full its full. theres really no channels or goofy things inside that wont get oil unless you drive it. i only remember mine taking like 3 or 4. if you want to be paranoid, drive it around for a day and recheck it
Old 05-03-2014, 08:12 PM
good to know. Thanks.
chiefbong360
12-17-2020 12:53 PM
Razorburn71
18
05-15-2011 04:52 PM
Dark79K5
12-29-2010 10:38 PM
trickett
10-13-2010 08:31 PM
fouronereason
09-07-2009 10:04 AM
Quick Reply: NP203 Only Took 3 Qts
