will my blazer haul it?
Old 11-01-2008, 07:28 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default will my blazer haul it?
my jimmys already got a AAL a real hitch and has 3:43s and trailer brakes if i keep it
i have a 89 XJ and i plan on getting a car hauler so lets say all together the load weighs 4500
if i install the airlift bags to help with the load do you guys think my jimmy should be able to haul it without working the crap out of it?
Old 11-01-2008, 08:10 PM
vin791 is an unknown quantity at this point
Default RE: will my blazer haul it?
with a 4.3, yes. with a 4 cyl probably not. with a 2.8? maybe. but i'd get 3.73s in that case
Old 11-01-2008, 08:37 PM
oops yeah its a 4.3
im hoping it doesnt put too much of a strain on stuff
Old 11-02-2008, 12:41 AM
with 3.43s you should be alright but if you're worried about it go3.73s. your gas mileage will suffer a couple points though. but no you should be ok without switching gears
Old 11-02-2008, 12:56 AM
thanks man now i can drop some money into both of my rigs instead of picking up something else
Old 11-02-2008, 09:49 AM
WolfPack's Avatar
The biggest issue is going to be the tranny...not the gears
Depending on where you drive it (hills and what not), you'll probably want to keep it in D3 instead of D. Overdrive is not good for towing. Also if you're going to be towing it alot, you might consider a tranny temp gauge as a good upgrade.
Old 11-02-2008, 10:13 AM
trans is a jasper unit. aux cooler is already on and a temp gauge is coming and i never tow anything in D
Old 11-02-2008, 10:14 AM
yeah but if he has lower gears (1:x) it will put more strain on the tranney. thats why he's talking about gears. and he has a 4.3 so it's the 4L60E. he should be good to go, but a tranney temp guage is not a bad idea. good though wolf pack
Old 11-02-2008, 03:19 PM
3.73:1 gears would help for sure, but 3.42:1 gears should not cause too many problems with the cooler and trans temp gauge.
The only reason not to tow in OD would be if the transmission was hunting or the torque converter was staying unlocked a lot. A transmission temp gauge will tell you more than enough information to allow you to make informed decisions about what gear to run in.
Old 11-03-2008, 02:34 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Also, you don't want to push the weight ratio between your truck and the trailer without trailer brakes.
Nothin' like slamming on your brakes and having the trailer keep going on. [:-]
MuTaLiZeD
03-21-2011 11:23 PM
k5blazer
14
10-21-2010 02:20 PM
ComputerNerdBD
05-08-2009 06:59 AM
BigBlue822
04-08-2009 07:35 PM
nezz19
07-11-2006 10:01 AM
Quick Reply: will my blazer haul it?
