General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
95 blazer a/c stops blowing through upper vents when I accelerate
Old 05-30-2006, 11:52 PM
budiblazer's Avatar
budiblazer is an unknown quantity at this point
Default 95 blazer a/c stops blowing through upper vents when I accelerate
When I accelerate, my a/c quits blowing through the top vents. I only blows throught the defroster or floor vent.
Old 05-30-2006, 11:54 PM
4lowlife's Avatar
Default RE: 95 blazer a/c stops blowing through upper vents when I accelerate
probably a diverter getting stuck/hung up.
Old 05-31-2006, 06:58 AM
magtec is an unknown quantity at this point
this can happen if there is a vacuum leak.
Old 06-01-2006, 01:56 AM
ACWiz's Avatar
ACWiz is an unknown quantity at this point
There is a vacuum reservoir on the passenger side under the hood. Typically it's a black ball type thing with vacuum lines into it. They leak frequently. Also, if there has been ANY other work done on the car, vacuum lines can get disconnected and not put back in place. Finding the leak is a difficult job sometimes.... so you will need a little luck, but that's all it is.
Hope this helps!
Old 06-21-2006, 09:57 PM
budiblazer's Avatar
I checked most of the vacuum lines. The upper vents work only if I place the control to bi level A/C. Will sporatically work when placed in the maxi A/C position.
JDHD
05-12-2021 05:01 PM
djsgarrett
07-08-2015 04:30 PM
msfan324
10-19-2012 02:27 PM
dunontme
09-22-2008 09:49 AM
tph1959
05-26-2007 07:56 PM
Quick Reply: 95 blazer a/c stops blowing through upper vents when I accelerate
