General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sponsored by:
Sponsored by:
Adjusting Timing
Old 08-24-2006, 07:53 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Adjusting Timing
I want to adjust my timing but my buddies dad said he needs to know the firing order. Does anyone know the firing order of an 88 with the 4.3?
Old 08-24-2006, 09:27 PM
Default RE: Adjusting Timing
Firing Order -> 1-6-5-4-3-2 & the distributor rotates clockwise.
One thing I don't know is if you have ecm controlled timing which would require the disconnection of the electronically controlled timing signal.
Old 08-25-2006, 01:18 PM
Thanks, I'm sure my buddies dad knows. We'll see I guess
Old 09-01-2006, 02:19 PM
Does anyone know which cylinder fires first?
Old 09-01-2006, 02:42 PM
as in... I guess I don't understand the question... Do you mean which cylinder is #1? If so, it typically is the cylinder on the front of the engine that is furthest forward. If you look at the configuration of the cylinders, you'll see that they are slightly staggered. Cylinders on the right bank are not straight across from cylinders on the left bank. This is true for just about all 'V' configuration engines (v6, v8, etc). So the cylinder furthest forward would be the #1 cylinder. In the case of the 4.3L, it is the driver's front cylinder.
So...
F|2---4---6|/--\
F|----------|DS|
F|1---3---5|\--/
Where 'F' is the front of the vehicle and DS is the distributor... I hope that comes out like I want it to... LOL
Old 09-01-2006, 02:46 PM
THATS PERFRECT!!! Awsome. Thanks a lot! Yeah that was my question, I was wondering if anyone would understand it. Thanks
Old 09-01-2006, 03:23 PM
Not a problem! Glad I could help!
Old 09-01-2006, 05:55 PM
Turned out it was already adjusted and advanced[:@]
MrJP
03-01-2009 04:15 PM
mrmaico
02-22-2009 11:16 AM
EuroGoldLS
07-30-2008 10:35 AM
stevelknievel
03-17-2008 11:37 AM
Scream And Fly
08-26-2006 12:25 AM
Quick Reply: Adjusting Timing
