General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Empty Radiator
Old 10-18-2006, 01:21 AM
DiRK's Avatar
DiRK is an unknown quantity at this point
Default Empty Radiator
After replacing the thermostat in my '86 Blazer I went on a 5 hour road trip... half way there I noticed I was overheating.
The Radiator was completely dry, and the overflow was completly full! I've never heard of this happening before, what could cause this?
I emptied the overflow, and refilled the radiator with fresh coolant, and so far on short drives it stays even.
-Thanks
Old 10-18-2006, 04:22 AM
Chevy Lover's Avatar
Default RE: Empty Radiator
It's possible that when you originally filled your rad that you had an air pocket causing the coolant in the engine to boil into the overflow tank and leave your rad empty.
When you replaced your thermostat and refilled your rad, did you run the engine to operating temperature (so the thermostat would open) and then recheck the fluid level after the thermostat opened?
janddcunningham
04-14-2011 07:35 PM
Trede
12-14-2010 08:03 PM
unklemike00
10-04-2010 06:44 AM
gERgMan
05-22-2008 12:30 PM
PawNtheSandman
05-02-2005 11:15 PM
Quick Reply: Empty Radiator
