General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
took dash apart and stuff dont work no more
Old 05-24-2006, 02:48 PM
jagblazer01's Avatar
Default took dash apart and stuff dont work no more
ok i pulled my dash apart to work on my stereo and when i put it back together stuff stopped working. everything is hooked up but my fuel gauge, water temp gauge, gear selector lights, odometer, and cruise control dont work...any thoughts? ima pull it back apart tonight and see if i see anything but id like some input please. lol this will teach me to take crap apart
Old 05-24-2006, 04:35 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: took dash apart and stuff dont work no more
how far did you take it apart? Sounds like one of your grounds isn't grounding.
Old 05-25-2006, 12:55 AM
[:@]ok well i discovered that my cruise control fuse was blown so when i replaced it everything worked...now i turned the truck off then back on again and now everything in my gauge cluster is lit up. the ABS light, the battery lights, my seatbelt sensor thing dont work, the security light wont go off, my low fuel light is on even though i just filled up yesturday, fuel gauge isn't reading...the list goes on. does anyone have any clue whats wrong before i blow my truck up and buy something else!!!![:@][:@][:@]
Old 05-25-2006, 01:01 AM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
this may sound out like an out there response. But Yea when my brother put a new headunit in he had to get a box to go in his dash for the RDS radio stuff. Well when he redid to the dvd indash he took that out and none of the gauges moved and all his things were lit up too. Could he just need to get the box or if its in there check the plugs and all on it.
Old 05-25-2006, 01:16 AM
ill try that....anyone else have an opinion?
steve72
09-01-2014 11:41 PM
Kayruss
09-28-2011 12:49 PM
Bode8692
06-19-2011 09:03 PM
Spartan66
08-01-2008 12:19 AM
88s10Blazer
10-16-2006 12:11 PM
Quick Reply: took dash apart and stuff dont work no more
